Проблема apt-get install libmapnik в Ubuntu 14.04
Geobotanic
Сообщение Geobotanic » 09 мар 2016, 18:16
Добрый день
При установке Mapnika возникает следующая проблема:
root@map2:~# sudo apt-get install libmapnik mapnik-utils python-mapnik
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 python-mapnik : Depends: libmapnik (= 3.0.0+dev20150425.git.d89033a-1~trusty1) but 3.0.0+dev20160113.git.6e93b05-1~trusty1 is to be installed
E: Unable to correct problems, you have held broken packages.
Как ее исправить?
Ваше звание: Author
Re: Проблема apt-get install libmapnik в Ubuntu 14.04
Сообщение Denis Rykov » 09 мар 2016, 18:45
Ошибка из-за того, что в Ubuntu 14.04 нет такого пакета "libmapnik".
Вернуться в «Веб-картография»
