gvSIG 2.1 финальная версия
gis
Сообщение gis »
gvSIG 2.1 доступен для скачивания.
http://www.gvsig.com/en/web/guest/produ ... /downloads
Из анонса:
The gvSIG Association announces the publishing of the gvSIG 2.1 final version.
This version, that is the first one based on the new architecture oriented to users, has a lot of new features as you can see now.
Besides the new functionalities and the correction of a great number of errors that have been detected thanks to the community collaboration, we want to highlight the availability of a distribution for Linux 64 bits and portable versions for Windows as well as for Linux.
Together with the gvSIG 2.1 releasing we publish the new gvSIG website, that includes the old gvSIG Association website as well as the project one, and at the same time a knowledge portal about the gvSIG technology. Besides this new website will be to make the new products of the gvSIG catalog visible, like gvSIG Roads or gvNIX.
We want to take advantage of this announcement to thank all the people that have collaborated in making this new version reality, and all the entities that have counted on the gvSIG Association services to solve their needs on geomatics, helping to guarantee the sustainability of the project at this way.
We hope you enjoy all the novelties of this version, that are:
- Legends
- Expresions
- Proportional symbols
- Graduated symbols
- Dot density
- Quantities by category
- Charts (pies and bars)
- Import/export SLD
- Copy/paste geometries
- Lateral buffer
- Split line
- Consecutive numbers function
- Duplicated records function
- Derived geometries
- Chart document
- Map sheets (map series)
- Connection with OpenStreetMap services
- New symbol libraries: Geology, POI Cities, Commerce, Military-APP6, Collective Mapping, Colors, AIGA, Weather
- PostGIS 2.x support (raster and vector)
- Layout
- Insert chart
- New layout with TOC (table of contents) included.
- New grid functionalities.
- Portable views (thematic maps plugin)
- Advanced dissolve geoprocess
- Labeling
- Advanced labeling
- Halo option
- Always show label option
- Raster
- Set projection to layer
- Change data type
- Create multi-file layer
- Convert to grayscale
- Integration of tools in the geoprocessing toolbox
- Principal components tool improved
- Georeferencing tool improved
- Tasseled cap
- Masks by regions of interest
- Export to KML
- Show attributes in ballon option
- Use labels option
- Reprojection:
- Reprojection forcing
- New EPSG projections support.
- Scripting: raster data support
- Layer loading:
- Dragging layers from the file browser.
- Memory management at the Preferences menu.
- Dyschromatopsia / colour blindness
- MsExcel format supporting as a table and a layer
- CSV support
- WFS service:
- XY axis order selection.
- Print performance improved
- New design of info tool
- Linux 64 bits supporting
- Bug fixing
We hope 2015 is a year with a lot of novelties, where gvSIG 2.1 and the new website are the first of them. Be aware of them!
Желающие присоединиться к проверке перевода интерфейса и исправлению ошибок в нем обращаться по этим контактам https://gvsigrussia.wordpress.com/contacts/
gis
Re: gvSIG 2.1 финальная версия
Сообщение gis »
Перевод сообщения о релизе gvSIG 2.1
https://gvsigrussia.wordpress.com/2015/ ... %83%D1%8E/
Вкратце - действительно много нового.
Но, старая проблема с проектированием данных из разных систем координат полностью не решена.
Впрочем, если работать с данным в одной системе координат, gvSIG вполне может составить конкуренцию коммерческим ГИС.
Особенно порадовали библиотеки символов. Для их установки надо Tools - Addons Manager - Standart и там в списке выбрать для загрузки.
Есть вполне профессиональные библиотеки для геологии, метеорологии, военных, коммерческие и даже для социальной активности
gis
Сообщение gis »
Кстати, если вдруг кто не обратил внимание, альтернативный сервер для загрузки gvSIG 2.1 - это собственно GIS-Lab :D
Испанцы упомянули еще сервер для загрузки, который поддерживает Евгений Богданец, но версии 2.1 там нет (надеюсь временно).
Сообщение Донецков »
С переводом меню пока не все хорошо, есть часть не переведенных пунктов, а есть "криво" переведенные...
gis
Сообщение gis »
С переводом все отвратительно, так как испанцы взяли часть от совсем старого перевода и часть от перевода более новой версии. При этом получилась страшная и непроверенная в интерфейсе каша.
Фактически все надо проверять в интерфейсе, сверять по ключам и кучу чего еще переводить, в том числе заново.
Если есть желание - надо составлять команду, делить по блокам в разделах программы (условно кто-то переводит и проверяет Вид, кто-то геопроцессинг и т.д.)
Проблемы глобальные две - 1) как компилировать переведенное для проверки в интерфейсе 2) как объединять разные части перевода
Вернуться в «gvSIG, KOSMO, uDig»
