Можно ли открыть такой hdf?
bolotoved
Сообщение bolotoved »
В архиве продуктов модис в части тайлов почему-то не прописана проекция. Например:
ftp://e4ftl01.cr.usgs.gov/MOTA/MCD43A4. ... 164253.hdf
Можно ли их как-то открыть, или это битые тайлы и нужно писать в поддержку?
gdalinfo выдает:
Driver: HDF4/Hierarchical Data Format Release 4
Files: MCD43A4.A2000225.h18v00.005.2008352164253.hdf
Size is 512, 512
Coordinate System is `'
Metadata:
  ALBEDOFILEID=6121997
  ASSOCIATEDINSTRUMENTSHORTNAME=MODIS
  ASSOCIATEDPLATFORMSHORTNAME=Aqua
  ASSOCIATEDPLATFORMSHORTNAME=Terra
  ASSOCIATEDSENSORSHORTNAME=MODIS
  AUTOMATICQUALITYFLAG=Passed
  AUTOMATICQUALITYFLAGEXPLANATION=Passed was set as a default value. More algori
thm will be developed
  AVERAGENUMBEROBS=0.795754
  BRDFCODEID=AMBRALS_V4.0R1
  BRDFDATABASEVERSION=v1.0500m
  CHARACTERISTICBINANGULARSIZE=3.01382091038871e-67
  CHARACTERISTICBINSIZE=1.546329376433893e+256
  COVERAGECALCULATIONMETHOD=volume
  DATACOLUMNS=1869507438
  DATAROWS=1193307767
  DAYNIGHTFLAG=Both
  DESCRREVISION=5.1
  EASTBOUNDINGCOORDINATE=179.999999543435
  EXCLUSIONGRINGFLAG=N
  GEOANYABNORMAL=False
  GEOESTMAXRMSERROR=50.0
  GLOBALGRIDCOLUMNS=1278170446
  GLOBALGRIDROWS=2020961897
  GRINGPOINTLATITUDE=78.924791655432, 84.4828767792245, 83.7673665113911, 78.547
5800834972
  GRINGPOINTLONGITUDE=3.02537104697637, -91.5363852806026, 145.423051056193, 58.
2586400253818
  GRINGPOINTSEQUENCENO=1, 2, 3, 4
  HDFEOSVersion=HDFEOS_V2.9
  HORIZONTALTILENUMBER=18
  INPUTPOINTER=MOD09GA.A2000231.h18v00.005.2006298172336.hdf, MOD09GA.A2000232.h
18v00.005.2006298101010.hdf, MOD09GA.A2000233.h18v00.005.2006308110331.hdf, MOD0
9GA.A2000234.h18v00.005.2006299082245.hdf, MOD09GA.A2000235.h18v00.005.200629916
2047.hdf, MOD09GA.A2000236.h18v00.005.2006299212010.hdf, MOD09GA.A2000237.h18v00
.005.2006300024629.hdf, MOD09GA.A2000238.h18v00.005.2006300111532.hdf, MOD09GA.A
2000239.h18v00.005.2006300205618.hdf, MOD09GA.A2000240.h18v00.005.2006301075851.
hdf
  LOCALGRANULEID=MCD43A4.A2000225.h18v00.005.2008352164253.hdf
  LOCALVERSIONID=5.0.6
  LONGNAME=MODIS/Terra+Aqua Nadir BRDF-Adjusted Reflectance 16-Day L3 Global 500
m SIN Grid
  MAXIMUMOBSERVATIONS=0
  NADIRDATARESOLUTION=500m
  NORTHBOUNDINGCOORDINATE=89.9999999919177
  NUMBEROFGRANULES=0
  PARAMETERNAME=Nadir_Reflectance
  PERCENTLANDINTILE=30.244064
  PERCENTNEWBRDFS=4.149078
  PERCENTPROCESSEDINTILE=51.642454
  PERCENTSHAPEFIXEDBRDFS=47.493376
  PERCENTSUBSTITUTEBRDFS=0.000000
  PGEVERSION=5.0.14
  PROCESSINGCENTER=MODAPS
  PROCESSINGENVIRONMENT=Linux minion5265 2.6.20.3 #1 SMP Thu Mar 22 09:36:24 EST
 2007 i686 IntelR XeonR CPU            5148  @ 2.33GHz unknown GNU/Linux
  PRODUCTIONDATETIME=2008-12-17T16:42:53.000Z
  QAPERCENTGOODQUALITY=0
  QAPERCENTNOTPRODUCEDCLOUD=0
  QAPERCENTNOTPRODUCEDOTHER=98
  QAPERCENTOTHERQUALITY=2
  RANGEBEGINNINGDATE=2000-08-12
  RANGEBEGINNINGTIME=00:00:00.000000
  RANGEENDINGDATE=2000-08-27
  RANGEENDINGTIME=23:59:59.999999
  REPROCESSINGACTUAL=reprocessed
  REPROCESSINGPLANNED=further update is anticipated
  SCIENCEQUALITYFLAG=Not Investigated
  SCIENCEQUALITYFLAGEXPLANATION=See http://landweb.nascom/nasa.gov/cgi-bin/QA_WW
W/qaFlagPage.cgi?sat=aqua the product Science Quality status.
  SETUPFILEID=6121997
  SHORTNAME=MCD43A4
  SOUTHBOUNDINGCOORDINATE=79.9999999928158
  SPSOPARAMETERS=none, derived from 3669
  TileID=51018000
  VERSIONID=5
  VERTICALTILENUMBER=00
  WESTBOUNDINGCOORDINATE=-0.0039836030015995
Corner Coordinates:
Upper Left  (    0.0,    0.0)
Lower Left  (    0.0,  512.0)
Upper Right (  512.0,    0.0)
Lower Right (  512.0,  512.0)
Center      (  256.0,  256.0)
Далее, если мы пытаемся загрузить 1-й слой этого растра в GRASS с помощью r.in gdal:
grass.run_command("r.in.gdal", input=HDF4_EOS:EOS_GRID:"MCD43A4.A2000225.h18v00.005.2008352164253.hdf":MOD_Grid_BRDF:Nadir_Reflectance_Band1, out=modis, quiet=True, flags="o")
Вылетает ошибка:
WARNING: G_set_window(): East must be larger than West
При этом слой не импортируется.
В QGIS такой слой вообще не хочет открываться:
"-hdf - не является поддерживаемым форматом растровых данных", хотя нормальные тайлы, имеющие проекцию, из этого же источника, открываются нормально.
lam
Re: Можно ли открыть такой hdf?
Сообщение lam »
Как вариант, попробуйте Global Mapper :)
Последний раз редактировалось lam 10 дек 2012, 09:13, всего редактировалось 1 раз.
rhot
Ваше звание: доктор
Сообщение rhot »
У меня тоже не импортируется ни в GRASS, ни в SAGA...
Сообщение Александр Мурый »
bolotoved писал(а): хотя нормальные тайлы, имеющие проекцию, из этого же источника, открываются нормально.
Дело, похоже, не в проекции. А в том, содержит ли конкретный HDF-файл растровые данные ("SUBDATASET") или нет. Упомянутый файл MCD43A4.A2000225.h18v00.005.2008352164253.hdf, судя по разграфке MODIS, находится около сев. полюса — может, поэтому там пусто? :)
Вот пример, как меняется размер (в байтах) HDF-файла в зависимости от широтного расположения тайла и наличия суши (возьмём тот же "столбец" №18):
1779471 MCD43A4.A2000225.h18v00.005.2008352164253.hdf
3457094 MCD43A4.A2000225.h18v01.005.2006309202627.hdf
18152003 MCD43A4.A2000225.h18v02.005.2006309025313.hdf
37085293 MCD43A4.A2000225.h18v03.005.2006308225409.hdf
46438591 MCD43A4.A2000225.h18v04.005.2006309024630.hdf
43443762 MCD43A4.A2000225.h18v05.005.2006309093138.hdf
61619366 MCD43A4.A2000225.h18v06.005.2006309102530.hdf
37000066 MCD43A4.A2000225.h18v07.005.2006309030412.hdf
281518 MCD43A4.A2000225.h18v08.005.2006309041126.hdf
307420 MCD43A4.A2000225.h18v09.005.2006309102038.hdf
221860 MCD43A4.A2000225.h18v14.005.2006309180008.hdf
224616 MCD43A4.A2000225.h18v15.005.2006309201553.hdf
852606 MCD43A4.A2000225.h18v16.005.2006309211252.hdf
Кстати, самый "тяжёлый" файл — MCD43A4.A2000225.h18v06.005.2006309102530.hdf (61 Мб) — приходится на Африку в области Сахары.
Отвечаю сам себе: здесь всё хитрее. Около того же сев. полюса тайл h17v00 (MCD43A4.A2000225.h17v00.005.2008352164521.hdf) содержит данные, а другие два соседние по горизонтали тайла — h16v00 и h19v00 — пустые.
Итого: в чём тут дело, не понятно. Может быть, какие-то ошибки в обработке данных.
bolotoved
тот же тайл за ту же дату, но за 2009 год содержит данные и открывается.
Даже так: файлы MCD43A4.A225.h18v00 с 2000 по 2008 - не открываются, а с 2009 по 2012 - открываются. В этом тайле присутствует и суша и водная поверхность. Скорее всего ошибка обработки.
namal
Сообщение namal »
Да, точно, вроде Cell Statistics, поглядел сейчас, что из себя этот модуль представляет. Тока бы под ArcView 3 или QGIS. Ну теперь хотя бы понятно в каком направлении копать, буду искать. Спасибо за наводку.
Sign up with 700-101 practice test - pass4sure.co.uk ccna for getting incredible online PMI courses exam and The University of Tokyo.
Вернуться в «Обработка ДДЗ»
