Ошибка сервера...
andreygeo
Ошибка сервера...
Сообщение andreygeo »
Может ли быть перебор файлов при загрузке на сервер? При попытке загрузить эксель выдана ошибка:
в System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
   в System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy)
   в System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy)
   в System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize)
   в System.Xml.XmlDownloadManager.GetStream(Uri uri, ICredentials credentials)
   в System.Xml.XmlUrlResolver.GetEntity(Uri absoluteUri, String role, Type ofObjectToReturn)
   в System.Xml.XmlTextReaderImpl.OpenUrlDelegate(Object xmlResolver)
   в System.Threading.CompressedStack.runTryCode(Object userData)
   в System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
   в System.Threading.CompressedStack.Run(CompressedStack compressedStack, ContextCallback callback, Object state)
   в System.Xml.XmlTextReaderImpl.OpenUrl()
   в System.Xml.XmlTextReaderImpl.Read()
   в System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace)
   в System.Xml.XmlDocument.Load(XmlReader reader)
   в System.Xml.XmlDocument.Load(String filename)
   в LayerData.ExcelImporter.GetExcelColumns(String excelFile) в F:\GeoMixer\Sources\GeoMixer\LayerManagerWeb\LayerData\ExcelImporter\ExcelImporter.cs:строка 90
   в LayerData.ExcelImporter.GetExcelColumnInfos(String excelFile) в F:\GeoMixer\Sources\GeoMixer\LayerManagerWeb\LayerData\ExcelImporter\ExcelImporter.cs:строка 63
   в LayerWeb.VectorLayerWeb.GetTableColumnsByCondition(String sourceRealName, String Types, Boolean nameOnly, Nullable`1 Identity, Nullable`1 Computed, User currentUser) в F:\GeoMixer\Sources\GeoMixer\LayerManagerWeb\LayerWeb\VectorLayerWeb.cs:строка 453
   в GetSourceColumns.GetResult(HttpContext context) в c:\inetpub\wwwroot\VectorLayer\getsourcecolumns.ashx:строка 33
   в CommonWebUtil.JsonHandler.ProcessRequest(HttpContext context) в F:\GeoMixer\Sources\GeoMixer\CommonSolution\CommonKosmosnimkiUtil\CommonWebUtil\JsonResponse\JsonHandler.cs:строка 26
Последний раз редактировалось andreygeo 26 ноя 2013, 15:31, всего редактировалось 1 раз.
Проект GISGeo: геомаркетинг
paleogis
Модератор
Ваше звание: Модератоо
Re: Ошибка сервера...
Сообщение paleogis »
andreygeo писал(а):Может ли быть перебор файлов при загрузке на сервер? При попытке загрузить эксель выдана ошибка:
Андрей! Вышли мне пожалуйста ексель.
andreygeo
Дело в том, что точно также организованный эксель загружался без проблем. Потом как отрезало. Уже изменял название. Загружал в другие папки. Результат тот же. Файл кинул на почту nikitaigran и на gmail. :cry:
paleogis
Модератор
Андрей! В экселе запятые, пробелы поубирал, все загрузилось. Так не должно быть, сейчас разбираемся с этой ошибкой.
Вернуться в «Веб-картография»
