GeoDjango, ошибка поля геометрии.
Кроме QGIS
Crackfox
Ваше звание: разрядник
Сообщение Crackfox » 01 апр 2019, 13:31
Добрый день! Никто не встречался с подонбой ошибкой?
Получаю ее при работе с api.
Cannot set Allotment SpatialProxy (POLYGON) with value of type: <class 'django.contrib.gis.geos.polygon.Polygon'>
вот полный трэк:
File "/home/user/MyProjects/forest-venv/lib/python3.5/site-packages/django/core/handlers/exception.py" in inner
  35.             response = get_response(request)
File "/home/user/MyProjects/forest-venv/lib/python3.5/site-packages/django/core/handlers/base.py" in _get_response
  128.                 response = self.process_exception_by_middleware(e, request)
  126.                 response = wrapped_callback(request, *callback_args, **callback_kwargs)
File "/home/user/MyProjects/forest-venv/lib/python3.5/site-packages/django/views/decorators/csrf.py" in wrapped_view
  54.         return view_func(*args, **kwargs)
File "/home/user/MyProjects/forest-venv/lib/python3.5/site-packages/rest_framework/viewsets.py" in view
  103.             return self.dispatch(request, *args, **kwargs)
File "/home/user/MyProjects/forest-venv/lib/python3.5/site-packages/rest_framework/views.py" in dispatch
  483.             response = self.handle_exception(exc)
File "/home/user/MyProjects/forest-venv/lib/python3.5/site-packages/rest_framework/views.py" in handle_exception
  443.             self.raise_uncaught_exception(exc)
  480.             response = handler(request, *args, **kwargs)
File "/home/user/MyProjects/forest-venv/lib/python3.5/site-packages/rest_framework/mixins.py" in list
  42.         page = self.paginate_queryset(queryset)
File "/home/user/MyProjects/forest-venv/lib/python3.5/site-packages/rest_framework/generics.py" in paginate_queryset
  173.         return self.paginator.paginate_queryset(queryset, self.request, view=self)
File "/home/user/MyProjects/forest-venv/lib/python3.5/site-packages/rest_framework/pagination.py" in paginate_queryset
  337.         return list(queryset[self.offset:self.offset + self.limit])
File "/home/user/MyProjects/forest-venv/lib/python3.5/site-packages/django/db/models/query.py" in __iter__
  272.         self._fetch_all()
File "/home/user/MyProjects/forest-venv/lib/python3.5/site-packages/django/db/models/query.py" in _fetch_all
  1179.             self._result_cache = list(self._iterable_class(self))
  63.             obj = model_cls.from_db(db, init_list, row[model_fields_start:model_fields_end])
File "/home/user/MyProjects/forest-venv/lib/python3.5/site-packages/django/db/models/base.py" in from_db
  507.         new = cls(*values)
File "/home/user/MyProjects/forest-venv/lib/python3.5/site-packages/django/db/models/base.py" in __init__
  424.                 _setattr(self, field.attname, val)
File "/home/user/MyProjects/forest-venv/lib/python3.5/site-packages/django/contrib/gis/db/models/proxy.py" in __set__
  75.                 instance.__class__.__name__, gtype, type(value)))
Exception Type: TypeError at /api/cutarea-allotment/
Exception Value: Cannot set Allotment SpatialProxy (POLYGON) with value of type: <class 'django.contrib.gis.geos.polygon.Polygon'>
Поле геометрии определено в модели так:
from renter.models import *
from classification_list.models import*
from django.contrib.gis.db import models
from django.contrib.gis.geos import Polygon
class All(models.Model):
    geom = models.PolygonField(geography=True, null=True, blank=True, verbose_name='geom')
    num_kvr = models.ForeignKey(QartalKeys, models.DO_NOTHING, blank=True, null=True)
    allot_num = models.SmallIntegerField(blank=True, null=True)
Кто-нибудь сталкивался? В интернетах что то полезного ничего не нашел. Модель вроде нормально определена. В postgres тип данных соответствующий. Не понмаю в чем проблема.
