GIS-LAB
Geographic information systems and Remote sensing
Installing .NET extensions for ArcGIS
How to install .NET libraries
502 Bad Gateway
502 Bad Gateway
nginx/1.18.0 (Ubuntu)
1. Download and install the .NET Framework version 1.1 redistributable package which includes everything you need to run applications developed using the .NET Framework (23 Mb)
http://www.microsoft.com/downloads/...
2. Insert ArcGIS Desktop installation disk into the CD-drive.
3. If ArcGIS windows doesn't appear after it, locate startup.exe file on your disk and run it.
4. Chose "Install ArcGIS Desktop" from the list.
5. Choose "Modify" on the next page.
6. Select ".NET Support" to be installed on local hard drive. Click "Next" to install .NET support. You won't see ".NET Support" in the list, if you haven't downloaded and installed .NET Framework (see 1 )
502 Bad Gateway
502 Bad Gateway
502 Bad Gateway
502 Bad Gateway
502 Bad Gateway
502 Bad Gateway
Дата создания: 26.03.2005
Автор(ы): Максим Дубинин
502 Bad Gateway
502 Bad Gateway
