Today suddenly a problem occurred with AutoCAD. When I try to print in PDF using a modified paper size (for example A2 format with length 840 instead of 594) it occurs a fatal error showed in the picture. I tried to search it in internet but have found different kind of problems.
This error occurs with all drawings (I tried a few), only if I choose to print in PDF with non standard paper size.
If I use normal paper size of PDFCreator there is no error.
проблема печати пдф с modified paper size
- Игорь Белов
Re: проблема печати пдф с modified paper size
Try another virtual printer. Get one installing PDFill entire package or just PDF & Image Writer.
