sudo apt-get update
sudo apt-cache search postgis
sudo apt-get install postgresql-9.3-postgis-2.1
Геоинформационные системы (ГИС) и Дистанционное зондирование Земли
sudo apt-get update
root@map2:/# sudo apt-get install postgresql-9.3-postgis-2.1
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
postgresql-9.3-postgis-2.1 : Depends: libgdal1 (>= 1.9.0) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
root@map2:/# sudo apt-get install libgdal1-dev^C
root@map2:/# sudo apt-get install postgresql-9.5-postgis-2.2
postgresql-9.5-postgis-2.2 : Depends: libgdal1 (>= 1.9.0) but it is not going to be installed
Сейчас этот форум просматривают: нет зарегистрированных пользователей и 43 гостя
© GIS-Lab и авторы, 2002-2017. При использовании материалов сайта, ссылка на GIS-Lab и авторов обязательна. Содержание материалов - ответственность авторов (подробнее).
